ghosting on realistic elevation views
4 ANTWORTEN 4
Nachricht 1 von 5
stephenwilliamsBSP
519 Aufrufe, 4 Antworten
Hi as subject were getting ghosting on realistic elevation views - see attached - when on the screen and when exported via PDF exporter but only on the office laptop. Graphics card issue?
cheers
Stephen
4 ANTWORTEN 4
Nachricht 2 von 5
dzanta
als Antwort auf: stephenwilliamsBSP
The times I have seen this it was due to a graphics card drive updated needed.  This is assuming your graphics card is compliant to run the version of Revit you are using.  Hope this helps.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Nachricht 3 von 5
Under Graphic Display Options: Depth Cueing or Silhouettes activated?
Nachricht 4 von 5
syman2000
Check with the material and see if there is glossiness turn up really high. Sometimes it may look like light is bouncing off the material and gives you these ghosting effect. As well adjust the light and see if that eliminate those ghosting.
Nachricht 5 von 5
stephenwilliamsBSP
als Antwort auf: barthbradley
not this time. seems to be a graphics card problem with a large model size
cheers
