Editable Titleblock
Editable Titleblock
tstewart
Editable Titleblock
tstewart
I've created a new Titleblock and saved/loaded it into Titleblock Family. Whenever I add a sheet into the project, the old titleblock appears and is not editable. How can I add the new Titleblock as the default Titleblock for all sheets?
syman2000
I would right click on the existing titleblock and select all instance in the entire project
Afterward, you swap it out with the new titleblock
tstewart
OH HAPPY DAY!!! Thank you much.
tstewart
I celebrated too soon. The new TB was saved & loaded into project, although the old TB is still displaying. What am I missing???
syman2000
You have to delete it from the project browser or purge it. Easiest way is to search the old titleblock and right click and delete it.
tstewart
I overwrote the D22x34 Titleblock, so if I delete it will that disappear in the project?
TS
syman2000
Yes it will disappear from the project. Before you do that, I would save the family to file and the proceed with the removing the family from the project.
