Cut and Fill: No Response
2 ANTWORTEN 2
Nachricht 1 von 3
averylin
253 Aufrufe, 2 Antworten
Hello, I'm encountering an issue with cut and fill operations. Here's the process I followed:
  1. I created a Toposolid in the existing phase.
  2. I used the "Graded Region" tool to create a new Toposurface that matches the existing one, changing the phase to preparation.
  3. I attempted to trim my Toposolid, which was created by the Graded Region.
However, I'm puzzled because the cut and fill values remain unchanged, even when I try to make significant alterations. Interestingly, when I copy the original Toposolid and test it in a different file using the same process, the cut and fill values are correct. I'm uploading the file if someone could help
I also have a second question: Is there a way to copy the points from the Toposolid? It's quite time-consuming to trim the Toposolid repeatedly.
2 ANTWORTEN 2
Nachricht 2 von 3
jay_colcombe
als Antwort auf: averylin
I an only suggest it is related to the Phasing and if you have lots of subsequent phases you have to create a graded region for each one.
When using in a New project with New and Existing i think it picks the defaults and is able to act as expected as it works as intended here too.
As regards the points, this is not possible but there is an idea already posted on the Idea community Form you could add your support/comment against.
Ability to copy Level points from one topo to another - Autodesk Community
Jay Colcombe
Autodesk Certified Instructor
Nachricht 3 von 3
Alfredo_Medina
Even if the user does this process properly in regards to graded region and phases, calculation of net volume and cut & fill volume is not working (yet) in Revit 2024, at least in the first build that I tested. I have not tested the latest build, but I did not see that issue mentioned in the list of updates. So, I assume that this will be taken care of in future updates.
