Edit the shape of wall bottom?
04:19 AM
- Mute
- Permalink
- Report
Hey guys!
I'm trying to make a dormer window where the bottom of the walls align with the slanted roof. I've managed to do it with two of the walls using "edit profile". However, I just can't get the same result with the last wall. I can't use edit profile since the profile from that angle is only a single line, and in-place void mass is a struggle as I can't seem to find the right work plane.
I've attached two images that I hope will explain the issue!
Thankful for any tips you have!
/Lovisa
