Edit System Panel Solid
Message 1 of 11
I am trying to create a curtain wall system panel that will adapt to a non rectangular shape. I have created a curtain wall panel with reinforcing that adapts to any rectangular panel, but does not work with non rectangular panels. The system panels adapt nicely however when I add reinforcing Revit no longer treats them as system panels. Is there a solution?
Replies (10)
Message 2 of 11
Only system panels can adapt to non rectangular shapes.  If you have some odd shapes, consider using nested curtain wall as panel, or pattern base panel off a divided surface, or repetitive adaptive component.
Sorry I cannot give specific solution since I cannot and will not open a docx file off the internet.  You should post pictures as JPG or PNG or PDF instead.
Message 3 of 11
Please find attached jpg files.
Message 4 of 11
another screen shot
Message 5 of 11
Use the first approach I mentioned in the previous reply: Create another curtain wall type with various vertical mullions like what you show in the picture and use it as the panel of the parent curtain wall.
Message 6 of 11
chrisplyler
For construction documents, I would just model using a regular panel, and then detail a section view to show the actual condition.
And please don't start the same thread three times.
Message 7 of 11
True that.  I wouldn't even detail them in my construction documents.  This level of details belongs to shop drawings, which OP is maybe doing.
Message 8 of 11
Would you please give me more information on How to do the following "If you have some odd shapes, consider using nested curtain wall as panel".
Message 9 of 11
See attached.
Message 10 of 11
Thanks everyone this seems to work. I'll play with it and if anything comes up get back to you.
Message 11 of 11
Viveka_CD
Hi @Anonymous
Thanks for participating in the community!
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you
