Good afternoon I'm in need of assistance on how to edit dome design. I created a dome using the revolve command it worked great, I was able to make it a half dome, My need it to carve out parts of it for a special design can anyone give assistance on the best way to accomplish this.
See the attach jpeg for example on what I shooting for.
Cut it with a void within the dome family, or cut it with a solid mass directly in the project.
ToanDN,
I created as a revolve, which gave me the axis as center to rotate 180, so I didn't get the option to cut it with a void, was there an easier way to make a dome or create a 1/4 dome, then how I created it?
I need it to be on ground level.
@brianwclayton1969 wrote:
ToanDN,
You can just select the finished revolve and change the angle directly.
ToanDN,
Is there anyway you could contact me and we can go over this. It would really be helpful.
I appreciate it.
Thanks Brian
