edit dimension style
hashpr
hashpr
HI
I am using baseline dimension
I want all Text keep aligned to baseline.
At the time I am doing it Manualy.
How can I do setting default to keep text align to Basleine.
Please find Screen shot.
L.Maas
I think you only can make it work when using ordinate dimensions.
Louis
Please mention Revit version, especially when uploading Revit files.
ennujozlagam
hi, just to follow up Enlint suggestion, you may also check it here. thanks.
http://www.revitzone.com/annotation-and-detailing/119-dimensions-an-introduction
hashpr
Thank you Louis for your reply and its really helpful.
I would like to know one more thing is that can we set in baseline dimension style, because we are mostly using that kind of dimensions in our model as you can see in recent image.
chrisplyler
The "default" dimension style will be the one you used last. So, to make this you're new default style, open the template file you use, transfer dimension styles into it, model a wall or something and dimension it with this style so that it will be the last style used. Delete the wall and dimension you made. Save the template file.
From now on, whenever you start a new project using that template, that dimension style will be ready to go.
