I was wondering if I can make the spacebar as a keyboard shortcut as 'repeat last command'?
Gelöst! Gehe zur Lösung
Gelöst von L.Maas. Gehe zur Lösung
No, space key is already assigned (hardcoded) to several functions in Revit.
You can use the keyboard shortcuts in the options menu to assign other shortcut to the command.
Louis
Please mention Revit version, especially when uploading Revit files.
Why is that?
This is my biggest complaint with Revit. It always seems to stop just short of being intuitive.
@Anonymous wrote:
Why is that?
The space bar as enter or repeat last command is a learned thing from AutoCAD. Hardly intuitive at all.
...Or you can use our free Add-On: BIM Repeat Remapper.
It allows you to remap the repeat last command to either the space bar, the right mouse button, or both...
How's that for intuitive?
Intuitive? By definition, questionable.
Creative? Yes.
Creative? Yes.
Fair Enough...:smileyvery-happy
By using spacebar as "enter" or repeat command can increase your speed significant. Also I use inventor, autoCAD and revit. Inventor and AutoCAD has spacebar as enter & repeat so it slows down me.
@birdtools, are the functions already associated to spacebar, such as Flip/Rotate family, affected by the addin?
And how plugins running in the background, waiting for certain actions, affect Revit performance?
@carolina.machadoIt's the only solution to achieve that functionality. I usually recommend getting used to the enter key, but old habits die hard.
Functionality related to the space key are remapped to the repeat last command and would not be functional if the tool is used. But that's configurable so they can get them back at any time. It's really a user preference, so usually users prefer the use of the space bar to repeat the last command, instead of what it is hard coded to do.
As for performance, give it a spin and let me know your thoughts...feedback always appreciated
Thank you @birdtools !
I used the plug-in a while ago and really liked it!
I just found some things that maybe can be improved:
Thanks for the feedback!
We have fixed the issue with the Text Note Editing in v2.0 and you can find it on the Autodesk App Store:
https://apps.autodesk.com/en/Publisher/PublisherHomepage?ID=9VRFRJVDDF6L
Let me check the right click issue you reported and get back to you.
Nice app. Can it be configured that spacebar accepts, for example, line lenght (when specified with numbers).
