Earth material
5 REPLIES 5
1533 Views, 5 Replies
Earth material
HI!!!
which is the diference beetween  Earth material (by default) and create new  material
Can i set Earth material on a floor element or another element ? or only can we use on topography
thanks
5 REPLIES 5
L.Maas
Materials can be applied to all elements that have a material parameter field.
You can apply the same material to different objects. But note that when you modify the material, the material of all objects with the same name will change too. Also note that several objects can have multiple materials. For example a wall can have multiple layers where each layer can be a different material. You can copy materials or create new ones and apply that to the different elements.
Louis
Please mention Revit version, especially when uploading Revit files.
Sahay_R
Topography. Create a fresh material for floors.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
in reply to: Sahay_R
@Sahay_R you mean I shouldn't apply Earth to my floors? Dang! I guess no turf on the inside of the house then. I guess I'll have to change it then. Thank goodness Revit Materials aren't object or function specific; meaning that you can apply any material to any object and it doesn't change the objects function. Smiley Wink
@Sahay_R
I am triggered as a hairy toed hobbit.
Sahay_R
in reply to: ToanDN
.....and here I was, trying to be all technical and profound.....sigh......
Rina Sahay
