E-Transmit Model button not show up
12 ANTWORTEN 12
Nachricht 1 von 13
gzhang25ARK2D
477 Aufrufe, 12 Antworten
|I tried to e transmit file,  but transmit model Button doesn't show up
12 ANTWORTEN 12
Nachricht 2 von 13
als Antwort auf: gzhang25ARK2D
Close the Project that you are Transmitting.
...do you get the "eTransmit requires all Revit Projects to be closed" message?
Help | eTransmit for Revit | Autodesk
Nachricht 3 von 13
gzhang25ARK2D
als Antwort auf: barthbradley
Yes., I did. But still not show up.
Nachricht 4 von 13
Are you saying there is no eTransmit under Add-Ins?
Nachricht 5 von 13
gzhang25ARK2D
It's not showing Transmit model Button.
Nachricht 6 von 13
If the Transmit a model button is not on the Add-ins ribbon then it has not been installed.  What is your Revit version?
Nachricht 7 von 13
eTransmit for Revit | Revit 2019 | Autodesk Knowledge Network
...same info as in link above, only prettier packaging. :zwinkerndes_Gesicht:
Nachricht 8 von 13
Nachricht 9 von 13
gzhang25ARK2D
als Antwort auf: ToanDN
It's Revit 2021. 1. 2
Nachricht 10 von 13
LT or Full?
If eTransmit is supposed to be included with your version (I'm not sure about LT), then maybe a reinstall is in order.  Maybe there was a prompt you blew by initially.
...shot in the dark: check your User Interface tab under Options and see if it's part of the tools not checked.
Nachricht 11 von 13
gzhang25ARK2D
If I reinstall, would possible I lose my existing file? How to do the
reinstall?
Thank you.
Nachricht 12 von 13
Nope. You won't lose it.
Before reinstalling, try Repair.  You do this through the Control Panel's Program and Features=>Uninstall Program.  Select the Revit Version and press uninstall. You will then be given the option to Repair.
Nachricht 13 von 13
Are you using Revit LT 2021?  Do you even have Add-Ins tab?
