E-Transmit Model button not show up
gzhang25ARK2D
Observer Observer
Message 1 of 14
gzhang25ARK2D
Observer
Observer
|I tried to e transmit file,  but transmit model Button doesn't show up
Replies (13)
Message 2 of 14
Close the Project that you are Transmitting.
...do you get the "eTransmit requires all Revit Projects to be closed" message?
Help | eTransmit for Revit | Autodesk
Message 3 of 14
gzhang25ARK2D
Observer
Observer
Yes., I did. But still not show up.
Message 4 of 14
Are you saying there is no eTransmit under Add-Ins?
Message 5 of 14
gzhang25ARK2D
Observer
Observer
It's not showing Transmit model Button.
Message 6 of 14
If the Transmit a model button is not on the Add-ins ribbon then it has not been installed.  What is your Revit version?
Message 7 of 14
eTransmit for Revit | Revit 2019 | Autodesk Knowledge Network
...same info as in link above, only prettier packaging. 😉
Message 8 of 14
Message 9 of 14
gzhang25ARK2D
Observer
Observer
It's Revit 2021. 1. 2
Message 10 of 14
LT or Full?
If eTransmit is supposed to be included with your version (I'm not sure about LT), then maybe a reinstall is in order.  Maybe there was a prompt you blew by initially.
...shot in the dark: check your User Interface tab under Options and see if it's part of the tools not checked.
Message 11 of 14
gzhang25ARK2D
Observer
Observer
If I reinstall, would possible I lose my existing file? How to do the
reinstall?
Thank you.
Message 12 of 14
Nope. You won't lose it.
Before reinstalling, try Repair.  You do this through the Control Panel's Program and Features=>Uninstall Program.  Select the Revit Version and press uninstall. You will then be given the option to Repair.
Message 13 of 14
Are you using Revit LT 2021?  Do you even have Add-Ins tab?
Message 14 of 14
hurmath93
Community Visitor
Community Visitor
2024
