Dynamo Package
Dynamo Package
BugFinder
Dynamo Package
BugFinder
I'm trying to follow a tutorial which uses dynamo to divide a curve equally and requires the node curve.PointsAtEqualSegmentLength however this does not show up in search.
What package do I need to install to get this node?  I've tried searching the internet at the package manager within dynamo but I cannot find this anywhere....
constantin.stroescu
it is in basic , but you have to use Dynamo 2.0
Geometry > Curve >...
Constantin Stroescu
BugFinder
I initially had Dynamo Studio installed but this was a lower version so I uninstalled and then installed Dynamo Revit which is v2 but now I cannot see any nodes after installation:
Any way of getting these back?  Not sure why they weren't installed as part of Dynamo Revit...
KrisAribal
Do you see the Settings tab? click it and then click manage nodes and package paths. Make sure there's a folder path listed there. If there's none then check this folder path:
C:\Users\<your pc username>\AppData\Roaming\Dynamo\Dynamo Revit\<dynamo version>
BugFinder
Yes, there is a saved path in there:
What files do I need to be in the folders?  I could do a search and see whether they exist on my system?
KrisAribal
open that link to your computer and check whether you something inside the packages folder. Btw,  you're using a virtual machine to run dynamo?
