Announcements
Dynamo: getting the section line aligned to a wall
a_qwaiderT68R3
a_qwaiderT68R3
hello experts,
I'm trying to create a section to every wall selected and it is mostly done, however, the section symbol line is placed far away from the wall and in some cases a bit higher than the level (which make it unvisible).
could any of you give us some orientation about how to solve this issue?
please find attached script and thanks in advance for your support.
I think some API experts have already created something, however, I'm not API expert and my team would prefer Dynamo solutions
regards,
Ahmad
L.Maas
Have a look at this thread. It might put you in the right direction
https://forums.autodesk.com/t5/revit-architecture-forum/dynamo-alignment-of-section-views-along-a-pa...
Louis
Please mention Revit version, especially when uploading Revit files.
handjonathan
Hi @a_qwaiderT68R3
Thanks a lot for posting your question to the forums!   Has the solution suggested by @L.Maas helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
