Trying to align section views perpendicular along a path at given intervals (chainage). Any advice and help would be appreciated.
Gelöst! Gehe zur Lösung
Gelöst von L.Maas. Gehe zur Lösung
Here a (partial) solution, rewritten.
The highlighted areas are the interval at which to section, and the size of the section view (width, far clip offset)
The part with the view direction of the section view is not working 100%, sometimes it goes in the opposite direction. Did not have time to solve that. Manual flip will solve that
Louis
Please mention Revit version, especially when uploading Revit files.
Then you should post on the Dynamo Forum
Also, be more specific. As in, I did X, expecting Y to happen, but instead, Z happened, what do I do? There's plenty of advice on how to ask a question, like https://forum.dynamobim.com/t/how-to-get-help-on-the-dynamo-forums/4677
@vancikv Thanks.
This was a continuation of a previous thread (HERE). There you can find more info on the issue.
I do not think there is an issue to ask Dynamo related questions here, it is Revit related.
The only thing is that at the Dynamo forum you will have a better chance to get good answers.
@michael.ocollinz Been better when continuing the previous thread instead of starting a new one.
It is always good to check on the forum rules/etiquette, it is a little bit hidden away
Louis
Sorry for the ambiguity of the question - I think the solution is spot on and will clarify on the question. I will however try to be clear with questions henceforth. Working with Dynamo core 2.12.0.5650 - Dynamo Revit 2.12..0.5740. Elegant solution by L.Maas to whom go my thanks.
