Dynamo code for the view cadres visibility
mahanmotamedi1991
mahanmotamedi1991
Hello Everyone,
I wonder if there is any Dynamo code for automatically making the views' cadres in the sheets of a Revit file visible?
P.S: before this, I found a code for hiding the project's base point, so I thought there was one for the task above.
Best,
Mahan
RDAOU
@mahanmotamedi1991
If you the view's Crop boundaries then you do not need a code...When printing, you can simply check the option to hide them and they will not print
mahanmotamedi1991
Hello, I'm aware of this option. It's more about the view cadres that I have manually hidden before, and I want to make them visible again, but I don't want to spend time making them visible manually.
Best,
Mahan
RDAOU
@mahanmotamedi1991
Put the following graph together and it should switch them either ON or OFF to your liking
mahanmotamedi1991
