Dimension Text Deleted While Synchronization
3 ANTWORTEN 3
Nachricht 1 von 4
BIMAbhi
242 Aufrufe, 3 Antworten
Facing one issue regarding dimension text (which we put by Dimension Text DB). Mainly while synchronize the linked file in the sheet file (base file) only the dimension text were deleted. For this, we have to put again the text in the dimension. We can't share the file as we are in NDA with the client. Attaching the snaps for your easy reference.
Before Synchronization
After Synchronization
Option choose to place the dimension text
Thanks & Regards
BIMAbhi
Beschriftungen (2)
3 ANTWORTEN 3
Nachricht 2 von 4
RDAOU
als Antwort auf: BIMAbhi
@BIMAbhi
Works fine here...nothing disappearing
After sync, if you double click the Dim to edit text, would the field be empty? ie: it disappears on screen only? I remember there used to be a glitch of disappearing Dimension text (above/below) which reappears after moving the text
Nachricht 3 von 4
BIMAbhi
als Antwort auf: RDAOU
Thanks for your quick reply.
It's empty after synchronization. Mainly while synchronization the Dimension Text "SOW" is not shown which shared in the snap. Please help.
Thanks & Regards
BIMAbhi
Nachricht 4 von 4
RDAOU
@BIMAbhi
Is it server based workshared model or cloud based? Is this happening only from a specific user workstation or everyone?
If it is only happening from a specific user account, you could try to clear collaboration cash if it cloud based or create a new local if the model is server based
Hard to tell when one is unable to recreate the issue...
