Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Dynamic price listing for Material takeoffs
Message 1 of 8
Is there a way by which I can create a schedule containing the Market price of Cement, Sand & Aggregate as parameters which I can update any time, such that when these parameters are used in formulas of material takeoffs, the values will be updated automatically?
Replies (7)
Message 2 of 8
@RDAOU ,
Can you suggest something on this?
Message 3 of 8
L.Maas
You can add an instance project parameter (e.g. unit price) to materials.
You then can create a material takeoff where you schedule that parameter.
Louis
Please mention Revit version, especially when uploading Revit files.
Message 4 of 8
Thankyou @L.Maas,
Can you share some sort of a small demonstration of this on a wall family? It will be easier for me to follow.
If I can explain myself in a bit more detail, we use Cement, Sand & Aggregate in both Columns and Slabs in a particular ratio(1:1.5:3). Similarly, Cement & Sand will be used in both wall plasters and tile screed in a different ratio(1:4).
If I am creating separate Project parameters specifying the cost of these materials for both Floor and Wall families, I am not able to borrow values from these parameters.
Hope I am not complicating the problem more.
Please guide me.
Message 5 of 8
RDAOU
@Anonymous
Apologies for the late reply, work comes first ... I do not usually do costing in Revit but you can do that using a couple of instance/project Parameters
  1. Go To Manage >>> Project Parameters
  2. Add New Project Parameter(s)
    • Instance
    • Select Category Material
  3. Repeat if you want to break down the cost to more than one material (example: sand + cement + aggregates + curing agent... => 4 parameter
  4. Go to view >> Schedules >> Create Material Takeoff Schedule
  5. Select category Walls or any other category you are scheduling
  6. Add the following Fields
    • Type (ie: wall type)
    • Material: name
    • Material: Area or Material: Volume (whichever is more adequate)
    • Material: Coast A, Cost B, Cost C (the parameters you added in steps 2 and 3)
    • Go to formatting tab and set the fields which need totals to Calculate totals
  7. If the parameters you added are unit cost (ie: 100$/cu.m then you will need to add a calculated value calculating the cost per ratio Cement/Sand/Water required)
  8. Add also a calculated value for the total
Message 6 of 8
denisyukJ
Hello everyone,
In addition to question above I've got a bit different problem.
I've got a batch of families which created by using lookup table and I want to add price to every type. Problem is price list updating every month and I will spend a lot of time for manual updating tables inside every family. Is there any way to automate it (or built in function)?
Thank you in advance.
Best regards,
Evgeny Denisyuk
Message 7 of 8
RDAOU
@denisyukJ
You do not need to open it in revit to update...they are tab delimited files you can open edit in excel, save and close
Message 8 of 8
denisyukJ
@RDAOU
Thank you for your reply. Yes, but I have to update this table inside family manually any way.
