Does anyone know howIi can change the direction my exploded view will follow? it seems to be following the faces of the view cube but i need it to run parallel with the pipes as shown in the screenshot
I know what you mean by displacing it by plane rather than axis but it will still follow the orientation of the view cube in the top right. I need it to move in the same direction as the pipes so then I need to be able to change the orientation of the red axis
The View Cube has nothing to do with displacement. Can't you eyeball it?
...just a thought: do you have any constraints acting on the element you are trying to displace?
The View Cube Orients the View.
Maybe this will help your understanding:
Turn the path to Jogged then drag the displaced element until the jogged segments appear inline. Then you can turn the path back to Straight.
not changeable...You control it by:
X Displacement = ±tan(Ɵ) * Y Displacement
Y Displacement = ±[any desired value]
