- Mute
- Permalink
- Report
We are having a graphic issue linking DWG file, which came from a consultant who uses Civil 3D.
We use "Link CAD" command under Insert tab. (Revit 2017) I use "Current view only", "Black and White", "Layer/Levels" is "Visible Only", "Import Units" is "feet" (whatever reason, it never auto-detects), "Positioning" is "Manual - Center". Then, the DWG comes in like this.
All zigzag and cannot figure out which line is what. Then, if I zoom in/out, the line shifts.
Above are all same inlet...
Civil consultant exploded the items, so these are all lines or polylines. No proxy.
I also tried without "current view only" and same result.
Interestingly, If I print this out, it looks correct. Below is screen shot of the preview.
I thought this could be a graphic card issue (machine is not powerful enough to process the civil data). So I used our rendering machine which is much powerful than my machine, and actually it got worse. I did not see majority of the lines, even though I linked the DWG file using same setting.
We tried everything we can think about (exploding, deleting unneeded object etc.) but cannot figure it out.
We asked around and it sounds like this is an issue specifically to this consultant. We also found out that another architectural firm who works with this consultant has same issue and has not been able to solve it.
Any input will be much appreciated.
Thank you,
Azusa Allard
