hello,
when i export DWF from any sheet, the DWF doen't have any object snaps inside the plans.
what im trying to do is to insert my revit DWF into autocad and snap on the dwf's objects.
what can i do to fix it?
and another small question is why my text getting distorted when i export to dwf ?( the spaces between words are suddenly getting smaller to the point that some of the words almost connect)
thanks
Hi @Anonymous
I see that you are a new visitor. Welcome to the Architecture forums!
Can you share some screenshots, the versions of Revit and share a file to test?
Also confirm if you are on the latest build of Revit, if not please go to your Autodesk Desktop App and check for updates and install them.
Looking forward to hearing from you!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
hey viveka, thank you!
im using revit 2018.3 build and autocad 2017.
this a screenshot from autocad after inserting dwf from revit sheet, as you can see no snap to corners.
i also attached the dwf from revit that doesnt have snaps when inserting to autocad.
what can i do?
Hi @Anonymous
You can Enable or Disable Snaps in Revit.
When you import or link geometry to the current Revit model, use the Positioning option of the related Import or Link dialog to specify how the incoming geometry is placed relative to the host model.
Let me know if this is what you are looking for and if you have additional questions!
Viveka CD
Yep....DWF's are pretty much images...so no snaps.
Why are you exporting to DWF? If you are going to be using CAD then export to DWG.
viveka im not trying to import anything to revit, i'm trying to import DWF(that was created from revit sheet) to autocad.
when im exporting dwf in autocad i have snaps, but when im exporting from revit the dwf doesnt have snaps.
so what else can i do?
Hi @Anonymous
Thanks for responding!
I see what you are saying. Can you share the file to test?
Viveka CD
Hi @Anonymous
I just wanted to follow up here, if you had a chance to send the files to test further.
Viveka CD
Hi!
Any updates on this issue?
I've the issue happening when I try to import DWF to Autocad, created by Revit.
File attached.
Thanks!
Lee
Attached DWFs in AutoCAD snap just fine. You need to make sure set the Print Setup under DWF Properties when exporting to Vector.
See the sample files.
It was working fine for a while, and suddenly now it stopped snapping again.
The only vector/raster processing I see on the DWF print export dialog is for hidden lines.
File attached
Lee
