Duopitch roof joining
atisklavins
Message 1 of 10
atisklavins
Hello all,
I cant join duopitch roof to bigger roof. Cant select edges.
I tried doing it without any slope, which was successful. But i lost options (red) to modify the roof.
Could you advise me, what am I doing wrong?
Thanks in advance!
Replies (9)
Message 2 of 10
martijn_pater
...why not just use the slope arrow/slope setting tools? (maybe add some images to see what you're trying to do)
Message 3 of 10
atisklavins
Ok, yes. I agree that that I have not added enough information.
I am trying to join these roofs. I know that I can make the from one roof, but I need them to be separated for schedule.  When i click on "Join roof" these edges does not show up when I point at them.
Instead I tried joining slab roof (i dont know if corrert in english). The edges could be selected.
When it was succesful, i lost options to modify the roof.
Message 4 of 10
syman2000
Have you try the roof join tool? Or you trying to do something else? Screenshot below how you can join the roof with another.
Message 5 of 10
RDAOU
@atisklavins
If it is a roof element, the Join roof should be able to pick it up...no reason why it shouldn't unless that Pitched Roof looking element is NOT a roof. How did you create them?
An easy way to limit the guessing is to upload that Revit model
Message 6 of 10
martijn_pater
...one common practise is to draw the adjoining roof overlapping and use the vertical opening cut tool on both those roofs' intersections.
Message 7 of 10
atisklavins
Thank you all for commenting. By the way, I am new to revit, so this might be silly to you pro's.
To fix this I had to make a roof (by footprint - as I did before), but without a split line. I defined slopes. Now the roof is connected. But with lees options to modify. Agues its because it is different type now.
Message 8 of 10
And, the two roofs (as seen in your screenshot) could be modeled as a
single roof. No joining needed.
Message 9 of 10
atisklavins
Yes, I could but I needed them to be different quantities in schedule.
Message 10 of 10
martijn_pater
FWIW/FYI if it's a single layer roof type assembly you could also draw it as single roof and use parts on it.
