Drawings on the sheet moved when printing as a single PDF file : GRID GUIDE
ysautodesklover
Message 1 of 11
ysautodesklover
I have found the strange behavior on printing when I printed several sheets ,which also had GRID GUIDE, as a single PDF.
As I deleted or make the Grid within full page of a sheet, the problem was solved.
Did anyone had same problem?
Replies (10)
Message 2 of 11
yurikim
Thank you for your posting @ysautodesklover
This seems similar to your issue:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Please try the workaround, and see if this works.
Yuri Kim
Product Support Specialist, AEC
Message 3 of 11
ysautodesklover
 Thank you for your comment, however I meant not Grids but GRID GUIDE for aligning views on sheet causes trouble when I printed sheets.
I attached some images on my comment so I hope you understand what I am trying to say.
Message 4 of 11
ysautodesklover
Message 5 of 11
chrisplyler
Your two pdf sheets appear to have different border widths and/or different page sizes. Hard to tell for sure from the picture.
Check the properties of both pages in the pdf file and confirm whether they are the same page size or not. If they are the same size, has one Revit Sheet been printed with a different Zoom value than the other?
Message 6 of 11
kadmonkee
make your guide grids smaller
when the guide grid exceeds the sheet size it will cause your issue
see image
I select the outer edge of my guide grid and adjust the grips to suit my needs then I move the view to a designated intersection (inside the circle)
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Message 7 of 11
ysautodesklover
Dear chrisplyler
As I attached the single PDF file, it has certainly different sizes on the two sheets.
If I print as tow separated sheets, it won`t happen.
Thank you,
Yuki
Message 8 of 11
ysautodesklover
deleted
Message 9 of 11
ysautodesklover
deleted
Message 10 of 11
ysautodesklover
Dear kadmonkee,
This is a workaround which my colleague found too or I might just delete  after making sure the sheets are in right positions.
Thank you very much!
Yuki
Message 11 of 11
kadmonkee
no need to delete the guide grids you can turn them off in the properties of the sheet
they will never print.
thank you
