Drawing Number with Revision Suffix
EdMilbourn
EdMilbourn
Hi
Is there a way by which I can automatically add a suffix to a drawing number to indicate the revision?
For example, say I have a drawing numbered 'BR23' that has already been issued. I then make revisions, place some 'revision A' revision clouds and want to reissue the drawing. The revision date is automatically changed on the drawing sheet. I also need the drawing number to automatically change to 'BR23A'. At the moment I have to go through manually and edit these. It's time consuming and easy to miss a sheet potentially causing problems later on.
Thank you 🐵
RDAOU
@EdMilbourn
On the Sheet:
You can set up the label to use 2 parameters
  • Sheet Number
  • Current Revision
See GIF below
EdMilbourn
Fantastic. I knew there must be a simple solution. Many thanks.
RDAOU
@EdMilbourn
For the Sheet List (Just in case you are wondering)
You can use combine fields using the same two parameter mentioned above Sheet Number + Current Revision
EdMilbourn
Thanks again 👍
