Draw arc
Draw arc
Message 1 of 12
Draw arc
Good morining,
trying to draw an arc on east side g my project but I can't.
When finish the skecth Revit say me " boundaries are not satisfied".
On south side instead I got.
See screenshot and .rvt please.
Thank's
Replies (11)
Message 2 of 12
. rvt
Message 3 of 12
Can't put the wall in correct position.
Message 4 of 12
When approach the sparrow on the pillar give error
Message 5 of 12
Are you editing the profile of the wall or using the opening tool?  In this case I would use a wall based generic model with the opening.
Message 6 of 12
Edit the profile.
How command can I use to do an arc?
Thank's
Message 7 of 12
There is a problem between the wall of the angle.
Message 8 of 12
@ToanDN can you help me please?
Message 9 of 12
I would follow @Anonymous advice.
Message 10 of 12
With which command?
Opening wall?
Message 11 of 12
Just copy one of your other walls that has the edited profile...Wall opening is square only....you would have to use a wall based family.
Message 12 of 12
