Draw a pattern or design like lattice
Message 1 of 15
Hi, I am trying to draw/extrude pattern in walls pls find attached.  Some are marked red square and blue colours.
Thanks.
Replies (14)
Message 2 of 15
hmunsell
Couple different ways you can do that.
  • Create an In-Place Model
  • Duplicate the default railing Panel-Glass and edit the panel
    • this would require you to put a short "railing" in the model to show.
  • place a piece of wall and edit the profile (not preferred)
Howard Munsell
Message 3 of 15
will you guide me or share a video for it?
If you guide for the first two methods separately that will be more helpful.
@hmunsell
Message 4 of 15
constantin.stroescu
Message 5 of 15
Another option for the railing details is to create a curtain panels, as the pattern is repeated. Hmunsell's railing solution is also worth consideration.  I would avoid modelling in place, or editing wall profiles, as this kind of modelling substantially slows down the model (and increases size).
For the other moulded decorations, these can be modelled in place, or create a wall based family.  Consider if you actually need them to be modelled.  I would suggest a line based detail family for elevations, or insert decals for rendering purposes.
Message 6 of 15
hmunsell
looks like @constantin.stroescu beat me to it.... LOL.
Nice video BTW :-).
Howard Munsell
Message 7 of 15
I saw both videos also tried both methods.
Files are not importing properly only showing only straight lines are showing. ( also showing errors)
also tried many different files also different format dwg dxf.  ( files are opening properly in AutoCAD )
please attach your Arabic clipped file.
Is there any pre-processing required to import file in Revit.
errors are --
the line is too short
cannot have overlapping lines
Highlighted lines overlap. Lines may not form closed loops. total warning 70878
Message 8 of 15
Could you please provide any guidance video, tutorial on how to do it.
@ TimELZ49
Message 9 of 15
constantin.stroescu
errors are --
all the warnings are true:
  • Revit do not accept lines smaller that 0.8 mm
  • it does not accept X intersections and overlapping
  • and all the lines have to be closed profiles ( closed polylines in AutoCAD)
That's why the CAD file has to be double checked prior of importing it into Revit.
If there are a few overlapping lines that "escape" in imported into Revit , then you have to solve the warnings first. What it matters is the quality of the imported CAD file.
Even the attached file had 2 or 3 overlapping and I had to clean them in Revit (it is an easier task here)
I think ,now it is cleaned...
Constantin Stroescu
Message 10 of 15
I followed your video carefully and imported your file in a fresh project.
I used your file ARABIC-TRIMMED-cs.dwg
got warnings
Highlighted lines overlap. Lines may not form closed loops. (8500 warnings)
Message 11 of 15
constantin.stroescu
Do you work in Revit LT?
Here you have a screencast in which you can see three methods and none with warnings...
Autocad 2013, Revit 2017...
https://knowledge.autodesk.com/community/screencast/6d73f720-bb57-4049-b0ff-457861f846a9
Constantin Stroescu
Message 12 of 15
constantin.stroescu
A few important things:
  • keep the same measure unit both in AutoCAD and Revit . I used mm in each application.
  • in AutoCAD:
    • Check not to have lines under 0.8 mm. If they are, then try to simplify the drawing, so to get rid of them.
    • Check overlapping : if my memory serves my right, AutoCAD has a function : kill overlapping
    • the quality of the CAD file is essential.
  • in Revit
    • only closed polylines will be taken in consideration for extrusion. If there are unclosed chain of lines then they have to be deleted....
About 8500 warnings you have mentioned in your post....Are there real  number of warnings or the checked item ID ?  I've seen rather big projects that have at most a couple of hundreds of warnings...
Constantin Stroescu
Message 13 of 15
Thanks for your videos and all work worked with your file. I tried with other files none of them is working. so the 2d cut is worked.
What about 3d work that is marked in blue ones. how to achieve that ( in question1.jpg).
I must say Revit is not good at importing cad files.
BTW, Thanks. Also, tell me how to extrude 3d that is marked with blue.
Message 14 of 15
constantin.stroescu
  • If you want a perforated screen or an extruded model like this:
then:
  • create a New Generic Model Face Based Family
  • load the image you want to model as background and use Extrusion
    • draw construction lines first
  • then , use Split Element (SL) , Trim and Trim Corner (TR) to obtain closed contours
  • and , Finish Edit Mode
  • Load the Family into Project and Place it onto a wall
  • in order to obtain a perforated screen create an opening into the wall
  • and you can place the Family on the wall or in an opening
  • if you want to place a more organic model onto the Wall , like this:
  • then you have to model it or/and combine a rough model made by Extrusion with a mapped material ( use the above image ) that will appear only in render image (you can obtain a very good result by using bump mask) , or with Model Lines drawn over the Extrusion ( as shown below)
    • create a New Face Based Family, load the bitmap as background , make a rough Extrusion and draw with Model Lines the details. The more work - the better result
  • load the Family into Project
Constantin Stroescu
Message 15 of 15
Thank you @ constantin.stroescu
your solution works.
I search whole internet but your solution was best.
could just pls post or share pre-processing cad file before importing in Revit.
But I must say Revit is bad in importing and extrude cad files.
if possible pls forward my word to Revit development team.
