Double sloped ceiling dimensioning
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all, thanks in advance for your help. This is an interesting problem, that I can't quite seem to figure out! I'm attaching images that will hopefully clear up any confusion my description may cause.
I have a ceiling plan that shows ceiling panels radiating from front (east) to back (west). The middle panels gradually slope from front (low elevation) to back (high elevation) - the furthest back panels are actually flat. The front elevation image shows that the side panels also slope from front to back, but have an additional slope to their sides (north and south). I then drew reference planes along the north-south slopes and east-west slopes and aligned sections to them to get plans for dimensioning. This is where I started to have issues!
The plans are just slightly off, so that angled dimensions for the corners have added decimals to them. The final dimension plan image shows the process I took to get these plans, and the bottom boxed plan is what I would like it to to look like. I get nice clean angled dimensions, but got that from linework, rather than one of the plans.
Is there a way to "flatten" out the panels in order to dimension everything in one plan, or what would be the best method to achieve this? We're planning on using double sloped ceilings in other projects, so if there's a way to do this without using linework, that would be great! Thanks!
