DOUBLE SLIDING DOOR FAMILY WITH OFFSET PARAMETER
jledgewood409
jledgewood409
wondering if there is an ootb double sliding door has a parameter that controls the offset from the exterior or something similar?
You mean a parametrically controlled inset like some OOTB Wall Hosted Families have?   You can build that capability into any Family you like fairly easily.
- Option 1: add the Offset dimension to the door family as an Instance parameter.
- Option 2: place a curtain wall the same size as the door to cut the wall, change the panel to any wall type, place the door to cut the panel wall.  You can move the curtain wall back and forth however you want.
- Option 3. similar to Option 2, but use a curtain wall door instead of a wall and a regular door.
jledgewood409
i figured that since the commercial ootb swing door has the parameter that all of the door would have it
Have you checked on-line? Here's one from Marvin. It's inset is controlled via "Inset to Installation Flange".
constantin.stroescu
I 've attached two such Families from my own database:
  • that with glass panel has a parameter that controls the distance from the wall the other one has a fix distance
https://www.youtube.com/watch?v=izVYwzGK6mE
Constantin Stroescu
