Dynamo Select elements in Player
Mike.FORM
Advisor Advisor
Mike.FORM
Why cannot I not see a selection interface in the dynamo player for this script. I want to select the path and the element to array. I have tried with the element preselected in dynamo also, but using the edit input icon still does not work. I have downloaded other scripts that allow you to select elements in the player and when looking at their nodes I cannot figure out the difference.
mhiserZFHXS
Just FYI, there is another forum dedicated to Dynamo.
https://forum.dynamobim.com/
But did you right-click the node and set it as an input?
Edit: @mhiserZFHXS beat me to it
Mike.FORM
OMG I feel kinda stupid now, I had right clicked the nodes but I didn't register those options as setable also doesn't help there is no visual indicator that the node has that property.
Also thanks for the forum link. I was only searching revit forums for a dynamo sub-forum.
mhiserZFHXS
That would be nice. That other forum is active and helpful, including with the folks who actually work on Dynamo. Might not be a bad idea to post that idea over there.
