I ve got an louver panel family based on nested array of louvers and I want to calculate quantity of louvers in spec. I know to do that I have to apply shared option for every nested family, but when I did that, family just crashed down.
This how it should looks like:
This how it looks after shared option applied for CurtainPanel_rev01 and Louver famalies:
I am kindly asking you to give me advise how to fix this because I am stacked.
Solved by RDAOU. Go to Solution.
All you need is to Edit the panel family and change Louver Count to a Shared Parameter this way you can add/quantify the number of louvers in the curtain panels schedule
Personally I prefer the panel family option but there is also the alternative of modeling the louvers as a nested Curtain Wall type which consists of
This way you can quantify louvers under mullions...both ways work.
Its pretty simple
You can find plenty of videos on google or even here....Here are the top hits on Google 🙂
