08:05 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am trying to create a dormer with a mansard style roof in Revit. Everything is fine except I cannot cut the roof under the dormer. I have tried to select the lines of the walls and the roof top but the line doesn't seem to close up and the cut cannot be generated. I get a troubleshoot saying the line is not closed and the dormer cut cannot be generated. I wonder if this may be because there are two roofs: one hipped with a cut and the other flat on top.
I have inserted a screenshot of the problem.
Any ideas how to make this work?
