Doors not showing!
Doors not showing!
selahforneyXGEU8
Message 1 of 9
Doors not showing!
selahforneyXGEU8
I can't seem to figure out why my doors aren't showing in my floor plans. It is only only type of doors also, my normal 30 x 80 doors are visible in the plan but I can't see the double doors I placed. They only appear when I hover my mouse over them or click on them. I checked the VG settings and they're on the right level.. any ideas? In the pic below that is me hovering over it, if my mouse was elsewhere you wouldn't be able to see it. doors not showing w mouse.jpg
Accepted solutions (3)
Replies (8)
Message 2 of 9
Do they show if you bump the Detail Level up to say medium or fine?
Open the Family and go to Plan View and then check the Visibility Settings for each of the Elements in the View.
The solution is amongst these 33 -- gauranteed:
https://www.ideateinc.com/blog/2013/01/missing-something-in-revit-view-33
Message 3 of 9
mauricio_mssf
One possibility is that your door is lower than the cutting plane so that the lines do not appear. Go to edit the family, select the lines and change the visibility setting.
Or This family may be configured not to appear at a level of detail like Coarse o medium, Go to edit the family select the lines change the visibility setting.
If the answer solves your problem, click Accept as Solution this helps other users to quickly find an answer and let a like if you liked it.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
Message 4 of 9
syman2000
Is the door in a group? check and see if you can restore all excluded
Message 5 of 9
cmilton
THANK YOU!!!
You saved me from a nervous breakdown.
Message 6 of 9
jmackey
SO FREAKING TIRED OF REVIT BS...! JUST GOING TO MANUALLY DRAW DOOR LINES....!
Message 7 of 9
Hand-drafting is the future!
Message 8 of 9
jmackey
Yup, least I know it will show on CD's...! Which is kinda what our job is...! to show the contractor what they need to build..!
Message 9 of 9
21a10004
In my case, the door in the revit family cubicle is not showing. Turns out I hide generic model category. Meanwhile, the door in the cubicle family is GENERIC MODEL. So I had to change the DOOR Family Category into Doors (Basically I can change it into anything / just unhide generic model caegory. But there are stuffs i need to hide under gengeric model category).
