For some odd reason none of my doors are showing up in the schedule I created. can some one give me a few things to check to see why?
are your doors definitely doors (and not for example, generic models) and is your schedule definitely a door schedule and not say a window schedule?
Check and see if any filters have been applied too - initially you want this set to 'None'.
Another reason would be in your Schedule Properties - Sorting/Grouping, make sure you have Itemize every instance checked.
If they are door families, then they will show up in a door schedule. Please ensure that the schedule that you have created is for doors. Make sure that doors are scheduled by Mark at the very least - that will help to identify the doors to the schedule.
Given that this thread started in 2015 I hope to god it's sorted by now!! 🤣
Try a multicat schedule and see if they show up there - if they do check the category parameter value and make sure they are actually doors. As far as I'm aware there is nothing broken in Revit in respect of scheduling doors.
my first post was a bit of a joke (because a 8 year old thread still being used is funny) however im attempting to fill out this schedule, maybe im missing something...
Not enough information to tell. I assume the Exterior Door and Level parameters are instance based since we can't see them in the type properties. Select a door and take a screenshot of its instance properties.
The other likely culprit is phasing. Do the doors exist in the phase the schedule is set to? For instance, are your doors all in the "New Construction Phase" but your schedule is set to "Existing"?
Something worth checking- is there a yes/no parameter that needs to be checked to force the doors to show in the schedule? Check that - assuming that the door families belong to the door category. Clear all filters from the schedule. Make sure the schedule is talking to the right phase. Are the doors coming from a link? Make sure that they are recognized by the schedule view template - or just remove the view template entirely. Make sure the schedule has the right Phase Filter set up.
Take your filters off and make sure you can see the doors you expect to see first, then filter down from there. As Rina has mentioned, make sure you check the phase the schedule is reporting as well if you still can't see your door(s) with the filters removed.
