Doors not displaying correctly in plan view
kajvanboheemen
kajvanboheemen
I've got a question. I've created my own door family (door 2 in the screenshot), based on the standard Metric Door. If I want to insert this family into my project and change the view to Plan View, I notice that the wall is missing lines. I assume it has something to do with the reference plane of the wall opening in the family file, but I'm not sure how to fix it. I've attached a screenshot that'll hopefully clear things out.
Also, in another family (door 1 in the screenshots), the door is cut off in a weird way (different than in the family). This seems to depend on the level I insert the door.
Does anyone know how to deal with these issues? Thanks in advance!
Looks like the door wasn't constrained properly to the size of the opening.  You can share the family and we can look at it.
kajvanboheemen
Thanks for your reply. Hereby I've attached both families. Please let me know if I can provide you with anything else.
For the front door, you need to set the frame to Visible in Plan/RCP.  For both doors, you need to set the 3D panel/ glass/ transom to Invisible in Plan/RCP.
kajvanboheemen
Ah, that works. Thanks so much!
