Revit - Groups
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
4563 Aufrufe, 4 Antworten
Revit - Groups
I have a problem with Revit groups. When I am trying to copy and paste by selected level I got an error and I can't paste group without ungroupping.
I got this error: Changes to groups are allowed only in group edit mode.  Use the Edit Group command to change to all instances of a group type.  You may use the "Ungroup" option to proceed with this change by ungrouping the changed group instances.
When I am copying this group to the left or to the right everythings is ok. The error appears during copying by levels.
I notice that this situtation has place only when inside of groups are doors. I am forcing with this problem from week and I have no idea what is wrong.
Maybe someone could check my file?
This situation is really strange, because at the beginning everything was fine.
4 ANTWORTEN 4
Nachricht 2 von 5
Alan.johnson1970
als Antwort auf: Anonymous
I tested your group and copy and paste to selected level works OK, no problems.
AJ.
Nachricht 3 von 5
I think its something to do with the SOFiSTiK Opening Updater add in tool.
And I dont have this tool.
AJ.
Nachricht 4 von 5
Sahay_R
als Antwort auf: Alan.johnson1970
Same with me. I don't have Sofistik - and the group worked perfectly for me.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 5 von 5
Yes ! Thanks so much! I did not think about that. I installed this add in recently... I tried copy and paste on different computer without this add in and it also worked well.
