Door with solid panel instead of glass
ruiterCV8G6
ruiterCV8G6
Hello all,
I am fairly new to Revit and for a project I am working on I have an issue with the door below.
In 3d view
This is a Aluminium door which I have downloaded from the internet. I want to replace the glass panel with a solid Insulated panel with the same color as the doorframe.
I have edited the family (with nested families inside) and deleted the glass. For the solid panel I created an extrusion and gave this extrusion the color that I want. For a visual check in the 3d model I have given the panel half the height of the doorframe and it looks like this.
When I load this into my project..... and check the 3d model.... I end up with the top picture (the original settings so to speak).
How can I fix this?
suganesh_matrix_a540
Instead of deleting the glass from the family, just change the material from glass to whatever that you want.
Just post the Family here.  Better yet:  Post both the original and your revised one.
