I am creating a door schedule and don't see room number on the list of the filed, I assume I can add one? I clicked the icon of new parameter between available fields and scheduled fields, I got a window of parameter properties, is this the way? if so, how should I fill the information in the parameter properties ?
Solved by ToanDN. Go to Solution.
That is not what I look for. The parameter will still be under door category, You can see, I already picked Dr Room Name, I assume that is Door Room Name, I want to add the field of Door room number. I checked the available parameters, I probably just follow this, though I don't quite understand why choose shared parameter, instance, values are aligned per group type, etc. Hmm, It didn't work. Once I chose shared parameter, parameter name grayed out. It seemed I should select a file, I had no idea what to select.
That shows you are adding the shared parameter to the project. Click OK to finish, go back to your door schedule and add that parameter in parameter list on the left side to the schedule field list on the right side.
Hi! You don't need to create a new parameter for this, that parameter is already included.
Inside of the doors field you have all the information belonging to the door, such as mark, family, cost etc.
If you open that tab and change it to "from room" you will have all the information pertinent to the room, you are still going to be inside of a door schedule but the information provided by the family is controlled by that tab.
I hope this is what you were looking for.
