door saddles and flooring material transitions
rteplow
rteplow
I'm adding a finish floor on top of the structural concrete slab and have had no problem adding a wood finish floor. I can't find anything on the board about what happens at floor transitions. In my case, there is a marble saddle at the door between wood and tile floors. I don't see a saddle/threshold family and I don't want to over model. I did switch out my door family and see a sill height parameter so that should help with bathroom doors. But I also have a framed opening between hall and kitchen where I also need a saddle. What do you recommend?
Sweep a Profile.
rteplow
Thanks, barth bradley, I'll try it. I haven't done a sweep yet - I'm guessing I draw a profile of the saddle shape and extrude it the width of the opening?
Yes. I'd create a few generic profiles to use and stick them in your library.  Use the appropriate one when the time comes.  Sweep a floor edge or a model line in the Project, or a Line-Based Family that you can pull across the transition in the Project.
...FWIW, I think Revit has some transition molding Profiles in the "Finished Carpentry" Subfolder of the "Profile" Folder in their stock Content Library.  If not, easy enough to create your own.
rteplow
Thanks again - this isn't the first time you've been helpful!
