Door openings are not showing
Message 1 of 14
I'm working on a student project and the door openings are not showing up nor are the walls connecting or the cut pattern showing, what could be wrong? I've checked the construction type and they are the same. My view range is correct (at least that I know of). Since I put topography in things are not working right and I've come to far in my project to start deleting things. revit.JPGrevit.JPG
Replies (13)
Message 2 of 14
Are you in a Floor Plan View?
Message 3 of 14
Yes I am in floor plan view
Message 4 of 14
Let's have a look. Post the file.
...here's a list of things to check when you can't see stuff.  Keep it handy for future reference too.
https://www.ideateinc.com/blog/2013/01/missing-something-in-revit-view-33
...here's my guess: there is no Opening in the Family or the Void Opening is not cutting the Host in the Family.
Message 5 of 14
No openings work for me, roof is showing in floor plans, I honestly have no idea what happened.
Message 6 of 14
Your View Range settings are wrong. Lower the Cut Plan to intersect with the Door Opening.
Message 7 of 14
They are though, level A as at the right elevation therefore I used that as the base for the view range..
Message 8 of 14
Message 9 of 14
You figure it out yet?
Message 10 of 14
Yes, sorry for the delay. How do I get the door panels back?
Message 11 of 14
Get rid of view visibility and graphic overrides you put on the panels.
Message 12 of 14
Message 13 of 14
Great, thank you so much!
Message 14 of 14
