- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
We are working on a project where we are using groups for storefronts that repeat through the project. The issue comes down to the schedule. Each door as part of the storefront group does have a unique door number which is what we want. But when we input an instance parameter into a door that is part of a group, they change all doors as part of that group (ie, hardware or comments). I thought I had done this before and it worked as instances, but perhaps I am wrong. Has anyone else come across this.
It may end up that I need to create a different group type if the instance parameters differ, but that would create more work. The best solution would probably have been to make a family, but the storefronts are easy to make.
