- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi everybody,
I've come across some cool video tutorials on how to properly model door families. There is the usual (very good) stuff presented by Revit Pure (12 Tips To Master Door Families), which I've seen in tandem with the other tutorial on how to create a nested door swing family (Create a Customizable Door Plan Swing). Once done the above, I wanted to test a door family that not only had the 2d info for the swing but also showed the actual 3d panel opening. To achieve that I've used the family created with the above instructions and edited following part of the instructions given in this tutorial by Balkan Architects: Door Family That Opens
Something not shown in that video is the handle. When I tried to insert it in that family and lock it to the surface of the door panel (and to the shorter edge to keep the same distance, no matter how wide the door it gets), when I changed the rotation angle the handle didn't follow the door panel. Any advice on which dimensions / parameters I should add to the family to make it work?
Cheers,
Gab
