İs there any way to change Pivot point .When I orbiting in my project it take a very far point as center to rotate .It is very hard to work like that.
Gelöst! Gehe zur Lösung
Gelöst von ennujozlagam. Gehe zur Lösung
This reply has been edited by the moderation team as the legacy links were no longer valid
you can try to refer to this LINK and see if helps. thanks
The easiest way, select the object you want to orbit around then orbit.
Mostafa Elashmawy
