Door family not resizing
2 REPLIES 2
brandt3BF9V
159 Views, 2 Replies
Hi all,
I need a door at 45deg instead of 90deg. I edited the family of the standard M_Single-Flush to shift the door itself 45deg (saved as different family name).
When I load it into the project - the default 915 wide door works great. But I need a 620 and 420 version of it also.
When changing the size in properties the gap in the wall will resize, but not the door graphic. Image attached.
How do I get it to resize? Or do I need to create separate instances for each size option I need?
2 REPLIES 2
jay_colcombe
in reply to: brandt3BF9V
It appears the 2D Detail Items and Symbolic Lines that indicate the Swing have lost association with the reference places that drive the width.  You will need to associate these and they will adjust for each Family.
You can add a Swing Parameter to control this angle if required, i have used this guide in the past but there are lots of videos on this.
Revit: Adding a 45 degree Door Swing using Visibility Controls - IMAGINiT Technologies Support Blog ...
Jay Colcombe
Autodesk Certified Instructor
syman2000
You should be able to change the angle if you load the default door from the cloud
Here you should be able to adjust the door swing angle
