Do shared parameters share their values?
For example:
Is there a way to make MySharedParameter update itself in Family2 when I change its value in Family1?
Solved by barthbradley. Go to Solution.
You need to Associate the nested Family's Shared Parameter to the Parent Family's Shared Parameter.
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-E2E6B19B-E47F-4F35-9F6D-1273A3248A50
@nozci wrote:I am using RevitLT. Is there nested family in RevitLT?
Hmm? 🤔 Dunno. I thought there was. Can't imagine LT not being able to nest families together. Do you understand what "nesting" is? One family loaded into another.
Read the information at the link I provided above.
I think you don't understand Shared Parameters. Read up on Shared Parameters.
https://help.autodesk.com/view/RVT/2025/ENU/?guid=GUID-E7D12B71-C50D-46D8-886B-8E0C2B285988
Also, search Revit OpEd archives for articles written by Steve Stafford about Shared Parameters. They are very good reading. Very enlightening.
https://revitoped.blogspot.com/
I loaded Family2 to into Family1 and next step is:
I don't have Model panel in Create tab if I am not missing something, here:
There is only detail component.
Thanks for the blog link. I will read.
