Cannot save this document because Color Fills are calculating.
Message 1 of 29
Hello, I have looked around on the forum but I don't seem to find anything, so I don't know if it is a problem of my own.
I just updated to Revit 2016 R2 and I keep getting this warning that says "Cannot save this document because Color Fills are calculating" every time I try to save.The same happens when I try to print, that it won't let me, but, oddly, it does let me syncronize. I have tried waiting for the color fills to finish calculating, but it never does, not even leaving it for over an hour, so the only solution I have found for the moment is closing Revit, reopen it and try to print quickly before the color fills start calculating again.
It is very frustrating and time consuming to do this every single time I have to print a PDF, so if someone could please help me out here I would really much appreciate it.
Thank you ver much.
Replies (28)
Message 2 of 29
dzanta
this is a known issue in revit r2...they are working on it.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Message 3 of 29
Okay, thank you very much, I hope they solve it soon as it is so frustrating.
Message 4 of 29
Same issue! how do we turn it off!!
Message 5 of 29
Kimtaurus
@Anonymous @Anonymous Autodesk has released an update to fix this problem.
Check your Application Manager.
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
Message 6 of 29
Great! I will check it out, see if it is solved.
Message 7 of 29
We are still getting this problem... we have had it a couple of times recently
We are working on Revit 2017.2.1
Build information:
17.0.1128.0
20170419_0315(x64)
2017.2.1
We are Anyone else...?
Message 8 of 29
With the 2016 R2 update I had the issue no more. Have never had it in Revit 2017 though. Maybe try updating to a later version if any
Message 9 of 29
shabik
Hi. I am having this issue with 2018. I need to save!!
Message 10 of 29
I have the same issue in 2018. The only difference I can save via the save reminder dialog, however if I just click save I get the warning dialog. I cannot sync as well.
So maybe a possible workaround:
  • Change the save reminder to the smallest possible value (15 mins)
  • Work and/or wait until the save reminder appears
  • Save
  • Kill Revit from task manager
  • Restart Revit, open the last local and sync with central
Message 11 of 29
vcerro
I ran into the same issue. What helped me was getting out of a view that has the color calculation. Go to a different view that has no color fill. Close all your views and give it a couple of minutes, then you should be fine to save.
Message 12 of 29
I have the problem even though I´m using Revit 2020. I have tried all  the trick you guys have written but its not working
Message 13 of 29
YaelNetser
Hi Ahmad, I just ran into this problem as well. What helped me was turning off the color schemes in my plans. When I tried to turn off via View template Revit crashed, so I created a new View template without the color scheme (by duplicating it in the VT manager) and then assigned it to my views. Of course this is temporary solution if you need the color scheme on. Try to do that, save, and then Audit... Good luck!
Message 14 of 29
this problem is still occurring in Revit 2021.
Its says colour fills calculating are the reason it wont save but the background processes are shown network calculation calculating also. Let this run overnight then had to crash the file and loose some some,. Same this happed today again. Turned off all calculations for piping systems, so what else could be calculating. No duct being used. I do have plenty of colour fills which i may have to get rid of.
Message 15 of 29
matthewsantana
Any update on this? Still happening on Revit 2021
Message 16 of 29
I turned off all pipe calcs and colour fills and this solved the issue. Its not the solution i wanted but its what i had to do.
It has put me off using colour fills in future.
Message 17 of 29
kritikap048
Community Visitor
Community Visitor
Thank you so much ....
Message 18 of 29
crodriguez
How did you turn off the calculations?
Message 19 of 29
Using Revit 2021.1.4 and facing the same issue? is someone in Autodesk working on it?
Message 20 of 29
jnelsonT5PWX
I'm still having this issue in Revit 2022. Any resolution from autodesk??
