- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm trying to use the "Create Parts" tool to divide a floor into two separate surfaces so I can leave the main floor with a horizontal line hatch to show hardwood and the smaller region showing a tile pattern. However when I try to do this with my existing floor assembly, once I complete the dividing function, the entire floor hatch goes blank (see attached images). What's more, I can't select the floor in plan anymore. The floor is still visible in section so I know it hasn't been deleted, but I can't select or see it in plan once the function is complete.
I tried the function on a new floor plate just outside my model and it worked fine (see image "test floor"). It's the same floor assembly aligned to the same level. Am I missing something? Alternately is there an easier way to assign a different hatch pattern to a separate floor area (without going crazy and creating totally separate floors?)
