Opening/Shaft with variable widths
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
Raymarcher
628 Aufrufe, 3 Antworten
How can this be achieved in Revit?
It seems the opening/Shaft tools are rather limited?
Greetings
2018-08-10 01_45_17-wee.max - Autodesk 3ds Max 2020 pre-release - Not for Resale (Athena with PDBs A.png2018-08-10 01_44_47-wee.max - Autodesk 3ds Max 2020 pre-release - Not for Resale (Athena with PDBs A.png
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Raymarcher
Sweep Blend
Nachricht 3 von 4
Corsten.Au
Create inplace model..instead of shaft.Create inplace model..instead of shaft.
Corsten
Building Designer
Nachricht 4 von 4
als Antwort auf: Corsten.Au
Or use a two-level generic family with a parametric void sweep blend to control the sizes of the top and bottom profile. Load in project and set the base at the lowest level, the top at the highest level, and use cut geometry to cut all the floors in between.
