Display of the Section Cut view range in Plan view constantly
Mark.Friis
Mark.Friis
Wenn looking in my plan view, I see a lot of section view symbol lines which tells me where the section view is locaed in the plan view. When ich click the section view I am showed the view range of that particular section view. How do I see all the view ranges of all the section views at once? and have them permanently shown in plan view? I want to print sheets where the view depths/Ranges of the section views are visible
cbcarch
I do not think it is possible.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Do you mean that you want the View extents , including Far Clip  Depth, of the Sections shown with the Marker on the Plans?  Sounds like an awful lot of linework. Typically, the Section Marker just indicates where you are standing in relation the to what you are looking at.  But, if this is what you are after, then maybe Scope Boxes could be employed here.  You can Print those.
