displace elements in Revit 2019
Yara-architecture
Message 1 of 26
Yara-architecture
hello.  this toolbar that include: add, remove... don't show up when i press edit. by side of that the element change to green and i cannot add or remove any element to it. any help, thanks in advance.Screenshot (1).png
Replies (25)
Message 21 of 26
When it is not green and you select it, does the Properties say that it is a Displacement Set?
Message 22 of 26
Yara-architecture
Screenshot (8).pnghere even i can not select ithere even i can not select it
Message 23 of 26
I don't understand what you are showing me.  Looks like it works in one view, but not another. Make a template from the view it works in, and apply that template to the view it doesn't work in. Or, get rid of the view. Maybe it's some sort of weirdly corrupted view.
Message 24 of 26
Yara-architecture
even in another project its not activeeven in another project its not active
Message 25 of 26
Yara-architecture
I am also don't understand what that. I cant make a template from another view because as I posted even in another not active.
Message 26 of 26
Yara-architecture
its the same view but it changed like that when I took edit.
