Direction of floor pattern
I created a tile floor with a custom pattern and applied it to two adjoining areas as separate floors for takeoff purposes. How do I change the direction of the office floor to match the main living area? I have tried the rotate tool, but after rotating and re-adjusting the floor outline, it changes back into the same direction it was before. Along with that comes a question that falls in line with that: How does one change a single instance of a wall/floor/object without changing the type?
Use rotate and align tools together if they are model pattern.
Hi, regarding the last question, I don't think it's possible to change the single instance of wall, etc. without changing the type of that instance. What you can do is, you can change the properties in instance properties without having to change the type of the object.
