Dimensions export IFC
dali.jmal
dali.jmal
Hello Community,
I want to lock a 3D view, dimension it and export it as IFC. The problem is that no dimensions are exported. Does anyone have a workaround or plug-in for this.
A similar Plugin but unfortunately not for Revit https://www.cds-bausoftware.ch/add-on-s/3d-bemassung
kristina.youngblut
Have you set the dimensions to IfcAnnotation in the IFC export settings?
Here is a link in case you need a reference.
I also found this handbook that discusses IFC.
Kristina Youngblut
Product Owner - BIMWorkshop
BIM Manager - CIMA+
30 years Autodesk User
A Tip A Day Project
LinkedIn
dali.jmal
Yes surely i checked that IFCTyp is set. I think this feature is not available in Revit, that is why i tried to search for some Plugin, but no luck here.
